Valve svela la classifica dei 100 giochi più redditizi del 2016
Da Salvo Messina · Inviato
No scusate volevo dire il 10980xe serie gold 18 core -
How to summon lightning in Minecraft If you are playing survival Minecraft, the only way to summon lightning is to get a trident that has the Channeling enchantment. The first step would be to obtain a trident. Tridents will only drop from drowned enemies holding a trident. Drowned will commonly spawn in deep oceans or rivers. You can also artificially spawn drowned by keeping a zombie underwater for 15 seconds. These zombies that convert to a drowned will never be holding a trident. You can increase your odds for a trident to drop from drowned enemies by using a sword with looting. Be careful approaching drowned enemies with tridents as they will use them against you. They will throw tridents at a decent range and getting away from a drowned with a trident underwater is no small task. The next step is to get the Channeling enchantment onto your trident. Channeling can be found in the enchantment table, but you can also find it in minecart chests, dungeon chests, librarian villagers, and chests from non-village structures. In the Bedrock edition, you can also fish up enchanted books that can contain channeling. Once you have a Channeling trident you just need to wait for a thunderstorm. While this is a rare event, you get to summon as many lightning bolts as you want during this event. Just hold your trident in your Hotbar, hold right-click, and release to see a bolt of lightning where your trident strikes. If you do not have the Loyalty enchantment on your trident, you will need to pick up your trident again. With the Loyalty enchantment, it will snap back to your inventory after a few seconds. Congratulations, you have the Minecraft equivalent of Mjolnir during a thunderstorm. To summon lightning through commands, you just need to type “/summon lightning_bolt”. This is the case for every version of Minecraft. If you want to summon a lightning bolt on a specific location, you can add coordinates after “lightning_bolt”. For example, “/summon lightning_bolt 320 70 -330”. Obviously, you can change the coordinate however you see fit. If you want to go a little more extreme and summon lightning bolts on all entities, the command changes a bit. You will need to type “/execute @e ~ ~ ~ /summon lightning_bolt'' to strike all loaded entities with a lightning bolt. If you want to exclude yourself from this command be sure to change the command to “/execute @e[type=!player] ~ ~ ~ /summon lightning_bolt”. You can add any other mobs you do not want to hit with lightning by adding a comma after the player and adding another type of mob. Example below. Click here to find out how to get how to get a lightning stick/staff in Minecraft:https://bit.rancah.com/aIjaiHGw
How to summon lightning in Minecraft If you are playing survival Minecraft, the only way to summon lightning is to get a trident that has the Channeling enchantment. The first step would be to obtain a trident. Tridents will only drop from drowned enemies holding a trident. Drowned will commonly spawn in deep oceans or rivers. You can also artificially spawn drowned by keeping a zombie underwater for 15 seconds. These zombies that convert to a drowned will never be holding a trident. You can increase your odds for a trident to drop from drowned enemies by using a sword with looting. Be careful approaching drowned enemies with tridents as they will use them against you. They will throw tridents at a decent range and getting away from a drowned with a trident underwater is no small task. The next step is to get the Channeling enchantment onto your trident. Channeling can be found in the enchantment table, but you can also find it in minecart chests, dungeon chests, librarian villagers, and chests from non-village structures. In the Bedrock edition, you can also fish up enchanted books that can contain channeling. Once you have a Channeling trident you just need to wait for a thunderstorm. While this is a rare event, you get to summon as many lightning bolts as you want during this event. Just hold your trident in your Hotbar, hold right-click, and release to see a bolt of lightning where your trident strikes. If you do not have the Loyalty enchantment on your trident, you will need to pick up your trident again. With the Loyalty enchantment, it will snap back to your inventory after a few seconds. Congratulations, you have the Minecraft equivalent of Mjolnir during a thunderstorm. To summon lightning through commands, you just need to type “/summon lightning_bolt”. This is the case for every version of Minecraft. If you want to summon a lightning bolt on a specific location, you can add coordinates after “lightning_bolt”. For example, “/summon lightning_bolt 320 70 -330”. Obviously, you can change the coordinate however you see fit. If you want to go a little more extreme and summon lightning bolts on all entities, the command changes a bit. You will need to type “/execute @e ~ ~ ~ /summon lightning_bolt'' to strike all loaded entities with a lightning bolt. If you want to exclude yourself from this command be sure to change the command to “/execute @e[type=!player] ~ ~ ~ /summon lightning_bolt”. You can add any other mobs you do not want to hit with lightning by adding a comma after the player and adding another type of mob. Example below. Click here to find out how to get how to get a lightning stick/staff in Minecraft: https://bit.rancah.com/aIjaiHGw
